Hey guys,
I'm about to have my '69 RR painted. This will be a daily driver so I wanted to ask a few questions. It is a numbers matching all original RR. No broadcast sheet but everything else matches and is original. Automatic column post car w/ A/C. The only thing that is currently not original on it is the rear axle, which is a true '69 Dana 60.
With that said, while I have everything stripped down, I have a few questions I wanted to run by you guys:
1.) Do you feel it would decrease the value if I converted it to a 4-speed and held on to the original automatic?
2.) The car is stock B7 blue exterior w/ white vinyl top and blue interior. If it was re-painted a different exterior color, do you feel this would affect value?
I plan on keeping this as a driver for some time to come...but should it ever get to a point where I had to part with it for some reason, I wouldn't want to have regrets on the modifications. Just looking for your thoughts. This is not a frame off. Just having metal fixed where it needs to and getting it repainted. Re-wiring and replacing with all new interior.
