pinkpanthr
Anyone know what color/tooth count pinion was used in the 1968 23-spline 4-speed?
I'm assuming your referring to the gears in the differential . How critical is the tire size of the equation, ? sorry Pinkpanther for high jacking your thread .
I have a spread sheet that you input gear ratio, tire size, etc, and it will calculate how many teeth you need on your speedometer gear. I will post it when I get home.
pm sentCan't put spreadsheet on website. Pm me your email address, and I will send it to you. Or give me your tire size and rear ratio and I will tell you what gear you need.
Read on one of the sites the guys posted that if it did leak it could get all the way up to the speedo? Def. don't want a cluster full of gear oil.if it looks like it is leaking, but I've never had to change one.
