Bryan_H
Good morning- I need to see if anyone can help me to identify this part- what is it for, and is it an original part of the vehicle?
It's located on the firewall, close to the driver's side (next to the master cylinder.) The heavy gauge red wire on the right is coming directly from the battery terminal. The heavy gauge wire on the bottom is heading to the starter. The light gauge black wire to the left- I have no idea what this is, or where it's going...bu the vehicle has no power (no accessory lights, will not start) if it's disconnected.
This square, box shaped part, is causing me some issues- I'm apparently not getting a good 12v connection here. I have to wiggle this thing around, sometimes, in order to get the vehicle to turn over (engage the starter.)
Any thoughts on what this might be? Is it necessary? Is it original? Is it just some type of power distribution block, with no real other functionality?
Appreciate the help, gang. Thanks!
