Air Cleaner
inri
383 that just a chevy motor
Either you don't know or you don't care; but there's a big difference between the two 383's.
For starters, one is the Real Deal, while the other is a reflection of...:lock:
oh he know quite well. Stuie is just stiring the pot.:chill:
4spd69RR
Winter Springs, FL.
Well Chevy combine parts from the small block 350's and 400's to create a stroker 382.67, rounded to 383. Next thing Ford will be trying to combine the 302 with a 351 to make their own 383 stroker small block. What is the world coming too, if that happens dogs and cats will start living together and will want Obamacare! Craziness, I tell ya, pure craziness.
4spd69RR
Winter Springs, FL.
Just received the new air cleaner, it's installed!! Now I am going to re-located my coil to the right side of the carb.
Looks good. Wondering how long you have had the chrome T-stat housing on the car or is it aluminum. The chrome ones tend to leak after awhile.
yeah mine had a chrome t sta that was leaking when I got the car.
the air cleaner ooks great
4spd69RR
Winter Springs, FL.
Thanks for the heads up, it is chrome. I do have an older cast housing, it was in real bad shape with a lot of pitting. Did not want to use it because I was afraid I would not be able to get it to seal. I'll keep and eye on the one I have installed.
