Horn Switch
4spd69RR
Winter Springs, FL.
I believe I have a bad horn switch, Does anybody have good pictures of all the components, the 69 manual diagram is for a different style. On my steering wheel I have a center button that twists on and off. behind that I have the horn switch with connection. Is there suppose to be any spacers?
I believe the first picture the switch was install backwards, however, that is how it was remove. One of the black spring loaded tabs is broken/cracked on the reverse side.
Mine is different but I might have that switch stashed away, Ill get back to you.
