dutchrunner
Hello , any of you guys have an solution to the melting of shifter cable from B&M ?
It is NOT next to headers(with thermo wrap) minimal distance 4 inch.
It is NOT an ground issue( out side is melting , not inside).
It is NOT possible to place heat shield due to TTI's and High torq starter.
It has an thermo sleeve around the cable(sparkplug wire sleeve).
Does any body know of a company wich makes these cables without this B.S. teflon .
I have changed 2 already sinds the last 8000 miles , I am starting to go :loco:
