OE Champion spark plug number for 69 440
resq302
northern nj
I know the OE factory installed spark plugs were made by Champion. What I don't remember is what the Champion part number was. Anyone know off the top of their head?
Thanks in advance.
Brian
I know you now have the answer but for everyone's info, Champion J11Y
That's because you can't find J11Y's. It's probably OK but a plug on the hot side can cause engine damage. On the other hand, you kind of need a hotter spark to burn today's cheap ethanol laced fuel. J14Y was standard on a lower compression 383 2bbl. I would just check the plugs to make sure they are not burning white. You want them to have a nice light evenly burned tan look.
?????? There is a man in the swap at Carlisle ever year that sells them for $35 a set. I also did a search on Ebag that turned up several sets but at a much higher price of course. But you are correct about needing a hotter plug with today's gas. It won't hardly burn when you light a match to it. LOL:
A friend of mine has a bunch of NOS J13-Y's. Is that just a hotter plug than the J-11Y's or would that be too hot?
