Dash light indicator (back up lights part 2)
Collin
Ok so I have the correct routing of the reverse light wire from bulk head to trans (thanks to you guys)
Up next I have to route and connect the wire coming from the interior "reverse" dash light indicator. The light is on the lower dash and has a wire with a female spade connector on it. Where does this connect? I assume it needs to be told when to light up by the trans module??
So this is the light with the female spade connector... This connects to the linkage? Not the fuse box?
That would be my guess, but I'm not 100% sure. Can't make heads nor tail of the wiring schematic.
Has nothing to do with the shifter it gets the signal from the revers switch on the transmission. I don't remember off hand where it plugs into but we can look into that
I have it marked as #7..... Not sure if it was correct originally....
It should connect to a black and white that runs to the bulk head connector. Pull up the wire diagram in the reference section.
This is where I am confused... Wiring diagram shows the backup lamp attaching to the fuse panel and sharing a fuse with the radio
The red wire you are looking at goes to the radio which joins a white wire at the radio plug. The white wire goes to the bulkhead D and changes to violet down to the trans switch. the black white off the other side of the switch goes to bulkhead C and Z, Z goes to your reverse light and C changes to violet to the rear bumper lights
When I get back to NY I will have to look at mine, but Bob is correct there is a Ball switch that threads into the tranny on the 4 speed,not a switch on the linkage.
I have the wire connected to the trans switch that routes to the bulk head. The interior reverse indicator on the dash just has a wire that comes off of it... Trying to locate where that goes
on the inside of the car, the black with white tracer wire continues from terminal "Z" directly to the reverse indicator light. there is a short purple ground wire that screws to the dash frame from the light.
I stand corrected. I guess I used the term "linkage" a little loosely. I guess I meant that it was activated by the linkage.
Collin look for the wiring diagram that has the bulkhead on it to see where Z is
Here's those diagrams if anyone else needs them
I really have to take pics to figure this out. So the light has one long purple wire with a female spade connection on it... I'll have to see what's in the Z location on the bulkhead now. I'll also have to look if it grounds anywhere like Mac said... No telling if this was after market or not
