Sixtynine_Bird
Hi guys!
yep it's been a long time! Sorry about that...
Anyway, last saturday I take the road for a ride put in it around 14-15 us Gallon and after 85-90 miles or so, the engine shut down. So of course I pull over on the right lane and then nothing! the car never start up again! i put 6 gall that i had in my trunk for sfety, and nothing happened! so i pop up the hood and saw that no gas were blow in the carb when i touch the throttle. So i guess it's the fuel pump cause it's only the 383 not a 500ci so i didn't use 15 gal for 90 miles! More over i was really kind with the throttle during my cruise so could'nt be a problem of gas.
Then when i arrived at my home after a nice tow with a 73 ranchero, i disassemble the carb and the tank of the carb were empty. i put som gas in it and the engine runs perfectly for 40 second till the tank of the carb get empty. So we guess that the carb is not the problem. so we remove the hose from carb and check if the gas was runnig out. the hose was just disconnect from the carb and just a little bit of gas comes out and then nothing. so we tried to blow the gas from the hose and when it comes we reconnected it on the carb immediately but once again nothing happened when we push the throttle nothing comming out from the carb. So the carb still dry.
Have you got any ideas of what the problem could be? can the depression could be the matter too?
Thnaks for your replies see you!
