I just wanted to share what happened to me last week while trying to remove my PCV from the passenger side valve cover on my 383. The PCV would not come out of the rubber grommet in the valve cover for nothing! I thought that maybe there was a bolt or something holding it in on the other side of the valve cover, but after removing the valve cover and inspecting the other side I found a splash shield preventing me from seeing the other side of the PCV. I did a little research and examined the replacement PCV and original factory part online and was convinced that nothing could be holding it into the valve cover but friction. I then decided I would go to town on the PCV and pull it out with force. I sprayed the rubber grommet with PB and let it sit to soften up the rubber. After about 10 min or so I used my vise grip attachment on my slide hammer to clamp down on the nut of the PCV and after 3 slaps it came right out ! Inspecting the removed PCV I could see that the metal PCV must have melted the rubber grommet in the valve cover and sealed itself in as a result of the engine heat. For all I know this could have been the original PCV. The area around the PCV which inserts into the rubber grommet in the valve cover had a nice coat of rubber melted to it. I was able to save the original grommet; but I replaced the PCV with a plastic one instead of the metal factory PCV to prevent this from happening again. Hopefully this post helps others if they have this issue since I ended up wasting about 2 hours playing with the PCV and researching online ! The moral of the story....don't worry about using force to pull out the PCV if it will not come out.
