Pillar Trim Needed
69RNR
Utah
I'm having trouble finding this piece now. Many of you were kind enough to help me with the correct bolts I needed (thank you) but now I can't seem to find this piece anywhere. It's the finished molding that goes around it. Would like nos but at this point, I'll take what I can get.
Once again, if you have any resources that could help me, it would be greatly appreciated. I took a pic of the one side with it, and the one side without it.
Thank you in advance!
Pete
Look in latest issues of mopar mags. I remember seeing someone started making these but I can't remember which one.
I'd check with Tony D, he's always coming out with new stuff, or might have used.
69RNR
Utah
I emailed Tony and he was kind enough to get back to me VERY fast! He said I need a pinch weld trim for the B-Pillar. He doesn't carry it but says it's the same stuff as the door jam pinch weld.
So....still not sure and still need to find it. I'll keep looking...
that's good to know, I'd never have guessed it was the same thing.
abodybill
Senior Citizen Member
MI. Farm
Hello 69RNR I thought I saw them in the book Just pulled mine and they do not look like the picture you posted not much to them but may check with a girl in Alabama it is a Mopar junk yard and she said they had interior trim and so on. Well just looked for the number but can't find it check the interweb for these mopar yard's. Also may check for b body's only. Well good luck bird brother. Beep.Beep..
69hemibeep where did you fine the windlace molding something to write down so I will also know later. Think I am starting a book on part's Ha Ha.
Mr. Moparts but he only has white and black. Some one just recently had posted it in colors.
Sublime 69
Pete
I was lucky enough to have this on this car but it need's to be refreshed. Some one said to put it into a plastic bag with silicone spray and let it soak. Is not much different than the door molding. Classic sell's the pinch molding. Russ.
Sublime 69
It seems the pinch molding does not have the flat area that covers the gap as seen in above picture without molding on
It has been awhile but I will have to look. Someone else was looking for this sometime back. Maybe someone reproduces it but have not seen it. I wanted to buy new but could not find it. :(
