6 bbl choke
Bill Monk
Dunbar, WV
Heat crossover is blocked and I don't want the starting problems of not having a choke. The choke that's on it is trash, if I replace the choke with a new piece, it will still open up fully, right? I realize it will take longer but as long as it opens, it's better than a manual choke.
It's the choke vacuum pull off that opens the choke. The choke thermostat in the manifold closes it. The pull off has to work.
You can probably use it, but I would set the thermostat to "lean" to make up for the lack of heat.
FWIW, I never used the choke in my A12.
