Motor identification
vso737
California
Can anyone tell me what these numbers indicate:
BLOCK CASTING NUMBER- 3614230-4
DATE STAMP BY THE STARTER- 17782 A
ENGINE ID#, RH ABOVE OIL PAN- 2C208217
CASTING DATE, RH MIDDLE OF BLOCK ABOVE OIL PAN- " D N "
My understanding is that this is a 400CID motor built in 1972 at the Jefferson, Michigan plant.
The sequential VIN# is 208217
I do NOT know what the " D N " designates nor the date stamping by the starter.
Finally finished .................
Pictures attached.
Thank you in advance,
LG,
Mikeengine number- lower left bottom- 808.jpgmotor casting number- 0812.jpgMOTOR ID NUMBER- RH OF BLOCK- 010.jpgRH OF BLOCK- DATE- 001.jpgHOOKER HEADERS COATED- 017.jpg
D- Dayturn
N-Night turn shift
Sounds GOOD to me, BUT both the D and the N casted in the block.
I thought the stamped number by the starter was suppose to be the date the motor was put together.
Thanks for the input..............
LG,
Mike
yes the D and N are both cast, but it loos to me that there is an arrow pointing to the D, which means your block was made on Daylight.
You are 100% CORRECT. I need to pay MORE attention to detail....................LOLengine number- lower left bottom- 808.jpg
Can you tell me what the STAMP NUMBERS by the starter reveal. I'm pretty sure it is suppose to be the date, hence, stamped and not a casting number. I figure the " A " stood for day shift................
Thanks again for all the help,
LG,
wrong picture..................
these numbers...................................
