Adding Spacer to clutch fan
I need to at a small spacer to move my fan into the shroud . The current bolts are to short and it does not look like you could get longer ones in the space the is provided between the pulley and the clutch fan. I can seem to get photo bucket to work or I would post a pic.
Any suggestion ?? I have a thin spacer that will be perfect
Thanks Tom C.
How far into the shroud is the fan? Ideally you only want the first 1/3 of the fan in there
It rides just at the outer edge and I have never had a over heat problem . I have a hp440 with a 26 inch Radiator. May be not necessary ???
