Nothing to bleed. Got it started but still has a miss. Like some injectors on the other bank are not working also. Had disconnect the IPC and start it. The IPC was sending a false message to the computer. Once started then plug it back in. Thanks Dave. So now going to pull the other bank down and test those injectors. must still have a bad one or two.
Darn truck just when I needed it !!!!!##
