Yep finally got the right tumbler to go into the old ignition switch. Though I was just about stuck with buying the conversion kit from classic. Also found the knob for the cig lighter on E Bay off Coronet for 25 buck's It was a hard Item to find. Got the gut's for every thing off Part's mix. But the ash receiver cost about 80 buck new or repro. So the hole ash tray is all their now. like we all ways say It is the little things that are hard to come buy. So persistence is a virtue if you got the patience's.
Now dag nab it I think I deserve a Ice Cold Beer.
I feel so dumb. Im going to removed the switch from the dashboard.
I don't know why the engineer designed thing's that way. Put some more nut blaster on it and let it soak. Here is something that might work mix one third vinegar to three part's water in a spray bottle. Spray that nut with the mix let it sit may take a couple of try's but the solution will work on the rust holding the nut. Hope this will help. Had a lot of people give me info on the sight while working on this runner. That is what a good group of guy's will do one motor head helping another. Good luck and the only stupid question is the one you don't ask. Latter Anthony. Russ.
