Denpsim
Antone using the holley Siper EFI thinking about giving it a try
Gnat, Any updates on how the Sniper EFI system is worked Gn for you? Considering adding a system to my RR.Yes I am using Holley Sniper EFI. Love it just a few bugs in starting. I think it is a fuel problem. I have my return connected a vent line. I ordered a sending unit with a return line so I will see if this is causing my problem.
Couple of questions. Where does the pump go and as far as soft fuel lines do you just change to injection grade soft or does it have to be steel
