All you need now is a 43 on the side!
Nice photo comparison, looks awesome.When I brought it home last Oct. And this Oct. Told my Wife I'd take my time. Sorry lol
Yep its right,the way it is on the bottom there's a lip that goes around the inside of the lip. Hey I wanted to ask you about your leaf springs, I read that you put the 6 leaf springs with the 2 1/2" arch how does your car sit with those? I was thinking about going the same route and getting rid of those long shackles. Thanks Anthony
This is with 8 inch rim's 275/R60.15x 8 inch. Got them from general sprig. I like the lift have the normal shackle on it stock size. It may crouch a little more when car is loaded. Had to put four cement blocks in the trunk to put the shock's on they are fully extended. After storing the springs for a while they had started to rust between spring so I ordered the plates that go between the spring's. broke them down painted them and put them back together with the plates between the spring's now I am happy. Hope you like the Idea. Beat's air shocks and longer shackle's. Russ.
