I don't understand all of this, but I found it interesting.
Big block VS. Small block. It goes to show that the mopar is far better than the chevy. First off the bore size is bigger in the mopar and the stroke is longer. The head dose in take more air and exhaust more air. Motor's are air mover's the more air moved through the motor the more out put you get. I would like to see a 383 with a turbo hooked on it and see what you can get out of it then. I have heard that they sell an 100 hp increaser turbo so now your looking at 500 or more hp out of the same motor.
Larger bore shorter stroke
6PKRTSE
Motor City
I argue with all of my brand X buddies all the time. What are the first thing all you brand X guys do when building your race engines with aftermarket race parts? The same things Chrysler did from the Factory. Bigger bores, bigger stroke (stroker motors), bigger valves, longer valves, shaft mount rocker arm assemblies, external oil pumps.
