'75 Road Runner rim/tire size
75RDRNR
My '75 has 50's on the rear and old E 70-14's on the front. I want to bring them back to stock sizes and can't find a straight answer anywhere. My local tire shop couldn't even find anything.
I need the original rim/tire sizes along with bolt pattern and back spacing info if possible.
I appreciate any help possible
15 inch rim's are your best bet. Not hard to find tires in that size. 14 inch are out dated if you can even find the tire's. I have 15 inch. 4 1/2 bolt pattern. It is a 69 sdon't know if yours is the same 4 1/4 back spacing on front and 4 1/2 on the rear. 7 inch width front and 8 inch on rear. Car look's nice with them. Many discussion's if you type into the search box. What rim's are you looking for.
Goldie originally came with 14” road wheels. 225/70/14 tires are still available. I bought a set of Cooper Cobras from Summit a couple of years ago. I think that Tire Rack carries them also.
I was looking into the Mopar Rallye style, but something similar will do. Thanks for the info. I will certainly look into those sizes
Since Goldie came with 14's, do you think 14x7's with a 5x4 1/2" bolt pattern and 4.25 backspace would fit bot front and rear? I like the Coopers and am considering them
Thank you for the help. I'm looking into Cragar Series 344 Rally with the Cooper Cobras
