Rim Measurements
75RDRNR
Is it possible the bolt pattern and backspacing could have the same measurement? For my bolt pattern I got 5x 4 1/2 and for backspacing, I got 4 1/2.
As you can probably tell, I have never ordered rims before. Thanks for the assist
Yes that is your correct bolt pattern and 4.5” backspace sounds about right for a 7-8” wheel.
75RDRNR
Last question on this thread, then I'm putting it to bed. Will a 17x8 wheel with a 4-1/2" backspace and a 4.5 bolt pattern fit?
Should not be an issue on the rear, but might have problems on the front depending on tire size. Interested in something like this?
75RDRNR
The ones I found were the Mopar Rallye Rims. I'm wanting to get back to the original look. The tires I found were 245/45-17. What would be the possible issue with the fronts?
75RDRNR
You think 17x8 in the front would be good?
Depends on tire size. I had a 245/40/18 on front without issues other than the ride quality was absolutely horrible.
75RDRNR
In your opinion, if I put the 17x8 on the rears, what would you put on the front?
75RDRNR
have had no issues with them
Your bird was on the Satellite platform and mine is off the Fury. Since there both B-bodies, they should be similar correct? So what works on yours, should work on mine?
