No fender tag
808RR
Kona Hawaii
With only a Vin tag, what info can I find out about my new RR ?
I want to build her right !
My car also did not have a fender tag. Look's like you know quite a bit about the car already. Four speed car console. Bucket seat's. Check the motor block to see if the vin matches the vin on the car. Facing the motor down on left where fuel pump mounts is the number where the oil pan bolt's on. Good luck.
808RR
Kona Hawaii
It's a match, I believe
Bingo your a winner. But have you run a mic. check on it yet. Mine would have had to be bored 60 over and that was way too much for an A/C car. My crank had a problem on third main bearing and had to find another one also a block. Was able to get a block that was stock and went 20 over which is not bad. 10 over on the crank. Happy with what we got in the end. They do make finder tag replacement's for what they cost think I will just buy a blank to put on mine.
808RR
Kona Hawaii
Ya, I have these. Haha
