Yea this one is about the same.Got my distributor from Summit racing. Cheap enough to just replace it. Think the hole kit was around 134 bucks.
I put the m&h harness in with the orange box I had ordered that did have the wiring harness but i didnt use the one with the wiring harness i used the m&h. The resistor is the double sided one not the single.They included a harness that would wire into your system. If I remember right got the orange box and the blast resistor with the kit. Knock on wood it is working well.
I'm glad you found the problem Russ.Chased my problem to this. I called jegs and they dont have a pickup that goes into the distributor and hooks to the harness. This was on the car when I got it.
Thanks for all your help. I appreciate it.I'm glad you found the problem Russ.
