440
Terry Hauck
Choadicus
Mojave Desert
Well, the engines in, the front disc brakes are done, and the power steering is back. Got to bolt on everything else, and it's ready to run. Can't wait.
Looking good. The day you sit in it and put the key in and crank it up. Head down the road and go through the gears is the biggest reward of all. Very nice work. Keep us posted. :thumbsup2:
Terry Hauck
Choadicus
Mojave Desert
I agree. I did everything myself but the machine work. Hoping for a good start up with no hiccoughs or leaks. Still got a bit to do but I'm closer every day. Install the 4 speed next.
Sound grate Terry. You will get the leaks stopped. The new brake lines where a bare to get stopped leaking. But after a while tighten and loosen then tighten again. Stainless steel lines.
Terry Hauck
Choadicus
Mojave Desert
I finally found it. It's a pinhole leak in the block about 4 inches up from the pan behind the starter. Maybe from the casting process at the factory. JB Weld to the rescue.
Terry Hauck
Choadicus
Mojave Desert
OK, all patched up. We will find out in 24 hours. Just a bit of blow by in the block, so the JB Weld should hold.
cosgig
Did I miss the sound clip? I’d really like to hear the beast!
