Electric fan for 22" radiator for overheating
Jim occhiuto
Smithtown NY
Has anyone installed an electric fan in addition to the existing clutch fan so as to help with overheating?
I have issues with overheating...22" radiator, clutch fan , no shroud as replaced orig radiator with a 3 row aluminum and old shroud won't fit.
Ant suggestions apprecìated.
Russ Hood
TN
Shroud is a big part of cooling. What fan you you have on it? Radiator cap? Thermostat?
Welcome! Many good minds on here to help you out.
Jim occhiuto
Smithtown NY
Don't have a shroud as I could get a standard shroud that fit on what supposedly was a direct replacement for my 22" radiator.
Measured fan..looks like 17" 7 blade with 8" clutch.
Just changed thermostat from 190 to 160. A little better but still hot. Waiting today for a 16 3000 cfm fan to arrive and hoping that will help.
Other than that I'm at a loss.
Jim occhiuto
Smithtown NY
Mostly at idle. It has a decent cam and a 3000 stall converter so it idles high.
Starting to wonder if transmission fluid thru radiator is a contributor
Low air flow at idle. Not big on electric fans but that should fix the idle issue but sometimes they can block airflow at highway speeds.
Russ Hood
TN
Blade is usually 18 5 i believe. Your at the same point i was. Idling with cam and stall will raise it up.
Jim occhiuto
Smithtown NY
Last resort will be like they did in Road Kill...nitrous spray on radiator!
Seriously...I'm going to measure airflow as is at idle in front of radiator using a cheapy anemometer i got from Amazon. I just got shroud yesterday that may or may not fit but I'll try to rig it up somehow and then measure airflow again. I'll post findings so maybe it helps others.
Im hoping a bit diff with shroud
V.R.D
florida
get a griffin radiator coast a bit but in Florida and a/c at a 5 min light best i ever had best money i ever spent.
Jim occhiuto
Smithtown NY
Russ...I bought what is supposed to be the correct shroud for radiator (22") but doesn't fit.
Expensive mistake. Gonna ask is anyone has pix of stock 22" radiator with a shroud as no way I can see how stock shroud would fit
6PKRTSE
Motor City
Add shroud for sure. I have several buddies that get away with no shroud. On Mopars and even brand X bars. I don't know how they do it. Except, none of them drive them as much all over as I do. I have always had to run a shroud on everything I own.
