Electric fan for 22" radiator for overheating
Jim occhiuto
Smithtown NY
Has anyone installed an electric fan in addition to the existing clutch fan so as to help with overheating?
I have issues with overheating...22" radiator, clutch fan , no shroud as replaced orig radiator with a 3 row aluminum and old shroud won't fit.
Ant suggestions apprecìated.
Russ Hood
TN
Shroud is a big part of cooling. What fan you you have on it? Radiator cap? Thermostat?
Welcome! Many good minds on here to help you out.
Jim occhiuto
Smithtown NY
Don't have a shroud as I could get a standard shroud that fit on what supposedly was a direct replacement for my 22" radiator.
Measured fan..looks like 17" 7 blade with 8" clutch.
Just changed thermostat from 190 to 160. A little better but still hot. Waiting today for a 16 3000 cfm fan to arrive and hoping that will help.
Other than that I'm at a loss.
When does it overheat? Idle? Cruising at different speeds? Stop and go?
Jim occhiuto
Smithtown NY
Mostly at idle. It has a decent cam and a 3000 stall converter so it idles high.
Starting to wonder if transmission fluid thru radiator is a contributor
Low air flow at idle. Not big on electric fans but that should fix the idle issue but sometimes they can block airflow at highway speeds.
Russ Hood
TN
Blade is usually 18 5 i believe. Your at the same point i was. Idling with cam and stall will raise it up.
Jim occhiuto
Smithtown NY
Last resort will be like they did in Road Kill...nitrous spray on radiator!
Seriously...I'm going to measure airflow as is at idle in front of radiator using a cheapy anemometer i got from Amazon. I just got shroud yesterday that may or may not fit but I'll try to rig it up somehow and then measure airflow again. I'll post findings so maybe it helps others.
Im hoping a bit diff with shroud
V.R.D
florida
get a griffin radiator coast a bit but in Florida and a/c at a 5 min light best i ever had best money i ever spent.
Jim occhiuto
Smithtown NY
Russ...I bought what is supposed to be the correct shroud for radiator (22") but doesn't fit.
Expensive mistake. Gonna ask is anyone has pix of stock 22" radiator with a shroud as no way I can see how stock shroud would fit
6PKRTSE
Motor City
Add shroud for sure. I have several buddies that get away with no shroud. On Mopars and even brand X bars. I don't know how they do it. Except, none of them drive them as much all over as I do. I have always had to run a shroud on everything I own.
cholley12
New Member
Pennsylvania
Swapping to an aluminum radiator is often just a Band-Aid covering for neglected tuning or airflow issues. Adding an electric fan or fans will increase the electrical load on the low amperage output alternator and put additional load on 50+ year old factory wiring. Both of those are negatives when adding an electric fan. Below is what usually causes overheating:
  • Retarded ignition timing slows burn and increases exhaust temperatures
  • Overly lean fuel mixtures run hot under cruise/load
  • Missing shrouds or wrong fan spacing kills airflow at idle
  • Low coolant pressure from a weak or incorrect cap
  • Incorrect pulley ratios reduce water pump or fan speed
  • Cheap aftermarket water pump
Fix those concerns first; you will often find the original radiator works just fine.
STXCUDA
Laredo, Texas
I've also never successfully cured an idle overheating issue with a colder thermostat. It's actually backwards. With a thermostat set to open at 160, the coolant temperature at idle will never dip below 160 therefore the thermostat will never hold the coolant in the radiator for a long enough time to allow it to cool down in the radiator, the coolant just flows through, yes it cools down but it would cool better if it got to hang out in the radiator a bit longer to dissipate the heat. My best bet is to always strive for the factory recommended thermostat of 190-195. That ensures the thermostat does it's necessary cycle to allow the coolant to stay in the radiator and properly cool down the engine. Yes it will run hotter but these engines run a heck of a lot cleaner and meaner around 200 degrees. Reducing the carbon buildup in the combustion chambers. With a 160 and insufficient low speed airflow you almost always get that constant rise in temperature as the car sits idling. Where as with a higher set thermostat and proper airflow you get a consistent temperature. I know it goes against a lot of what we have learned but I have had my fair share of overheating battles down here in south Texas and since I've adopted that philosophy I achieve the target temperature every time. Electric fans are a last resort. usually only added if the electrical system has been updated/upgraded and if the car has an A/C system so that additional airflow is necessary to keep everything happy. Otherwise I stick to 7 blade 17 inch fans, HD clutch and shrouds.
Jim occhiuto
Smithtown NY
Thank you so much for the info. I am going tobdobsome temp measurements on the radiator to make sure I'm getting a 20 to 30 degree temp diff when idling . I have a new water pump with more flow rate than std that I have to put in.
I'll keep you posted on progress.!
Jack R
Gilbert, Arizona
I went through a few different electric fans on one of my cars. I ended up with a Zirgo fan which still works great a long time later.
