Air filter base and top plates.
Ok so here it goes. my base plate on the air filter for the air grabber system has a bridge in it with a hole in the middle to tighten it to the carb. Also two studs to hold the top plate in place. Mine is hitting the carb and won't allow It to fully seat to the carb. Have cut it off and the base plate is fully seating on the carb. I don't see any way to install the top plate except to drill a hole in the middle and put a wing nut too hold the assembly to gather. Any thoughts or what you did in this case. Thanks Blue.
We'll have been working on the air filter. One thing leads to another. Cut it down to work with my holey intake. Took a washer and welded it to the all thread with a lock nut to keep it from unscrewing that holds the base to my carb.cut the cross bar down that holds it in place. One thing leads to another. Hood closes well now. Now moving on to the air grabber parts that a fix to hood. Hope things go smooth and can say it is done. Lol
