road robert
I dropped the steering column to remove the instrument cluster at which time found that only the 2 nuts on the studs were securing the column (3rd lower bolt missing) and that they were not centered in the rectangular breakaway plastic washers, were towards the steering wheel end (and breakaways broken). I also had to remove the 3 bolts down at the firewall to get it to drop, which I thought was strange. I bought new breakaway washers and can pull the column closer to the driver to better center the mounting studs in the 3 breakaway washers (still not quite centered but closer) but then the column shaft is farther out of the gearbox. My question is does it matter if the shaft is pushed all the way into the gearbox or pulled out (it stops ~ 1" out) so the 3 column fasteners are better centered in the breakaways? I wrapped blue tape around the shaft to see the 2 positions (in/out) for reference…
P.S. This car was completely taken apart some time ago for a rotisserie resto so I am finding a lot of little stuff that is wrong…
Thanks!
Thanks!
