I've heard about some less that flattering things about the Voodoo cams in Chrysler products. While I can't verify these comments I have read posts on other forums from Voodoo owners who don't like them for one reason or another. Who knows - could be guys who don't really know what they are doing or know how to select the proper cam for their combination.
My recommendation these days is to get a cam that is designed specifically for the large diameter Mopar lifter. Since GM, Ford and Chrysler engines all used different lifter diameters, cams were ground using compromise designs based on the smallest lifter diameter. Since Chrysler lifters are the largest in diameter they allow the designer more mechanical leverage. Also get a cam designed with the newest lobe profiles known as "fast ramp" design. This design allows for popping the valve open quicker which keeps the valve open longer than a cam designed w/o fast ramp technology. And as always, get the springs, retainers and locks specified by the cam manufacturer. After all, they designed all this stuff to work together.
