Hoosier Bird
Went to fire the car up and it wouldn't start......No fire........Got voltage to the coil......(Blaster).....how can I check the pickup in the distributor and the Mopar brain box? :brickwall:
i would bet the balist resister or the ecu box , i alway carry an extra one of both in my trunk , and a coil . my 2centsHoosier Bird said:Went to fire the car up and it wouldn't start......No fire........Got voltage to the coil......(Blaster).....how can I check the pickup in the distributor and the Mopar brain box? :brickwall:
yeah take it over to your other mopar :jester: :jester: oh yeah thats me who has severalHoosier Bird said:Is there a way to test the module without replacing it........Chime in here Big...............
moparstuart said:yeah take it over to your other mopar :jester: :jester: oh yeah thats me who has severalHoosier Bird said:Is there a way to test the module without replacing it........Chime in here Big...............
you might make sure its grounded well also I always use those biter washers to make sure it gets a good ground on the fire wall paint
YOU CHANGING THE DISTRIBUTOR AND COIL TOO??Hoosier Bird said:Grounds are good..............I've got a 6AL that I'll prolly put in tomorrow.......
get that thing running it's getting nice out , cruising time get off that buttHoosier Bird said:Sorry Stu.......just been putting a rear end in my recliner........I have got to get motivated........ :toetap: :toetap: :toetap:
if it wont even crank i would pull the bulk head plugs and clean them first , main plugs on the fire walldobie said:Well, I'll be awaiting the update now as well. I went out yesterday to move the x's Satellite to change a light bulb, and of course no start. I had switched ballast resistors to bring it over here last fall. I changed them yesterday again and nothing. Made sure the battery was fully charged and tried 2 different ballast resistors as well. Nothing. The "brake" warning light will come on for a second, then fade away quickly. Doesn't even crank. No electronic ignition stuff, so no box to swap out.
:huh:
Yep, that sounds like a good place to start. When my car has sat for several months like that I would always charge up the battery before I try to start it. This may not make a difference but I take the cables off the battery so there is a direct connection from the charger to the posts.dobie said:The car has sat since October I'd say. The only thing it did was click a few a few times, almost as though it was coming from the battery. I say this as the first few times it clicked I saw a small puff of smoke from the positive terminal. I'm guessing it's time to clean the terminals, eh? There is some slight corrosion on the positive cable.
