cross member and tail panel
Any one reproduce that weld strip. It fits between the cross member and trunk floor and the tail panel welds to it If you have any pics of what you did to replace it would be appreciated. Russ.
Nope it was attached to the trunk pan. Just had cut the metal and bent it was fixing to make it then said I wonder if that was part of the old trunk pan. Sure enough it was so cut It off and cleaned it up back their. Ready to weld in new trunk pan. Russ. :thumbsup:
dmartin
When I put my trunk pan in I notched around that middle brace and used seam sealer on it good as new
