dash - remove or not
Big Mo
Pa. USA
I have the 68 bird torn down that only the dash and side windows are left on car. In my last Mo magazine there is a article on removing the dash. Just wanted to ask you for your suggestions if this is something I need to do. If it is the article makes it look easy. I read the thread on painting the letters and I will do that. If you have any suggestions or recommendations I really would appreciate it. Thanks.
If the windshield is out, the dash comes out fairly easy.
Make some stands too. I made some out of old bed frame. Here's a couple pics of them holding my 300 dash and my 53 Windsor dash.
AMX GUY
Oregon
If you need to work on the dash then pull it. I did it on my Super Bee and it's not that tough, I'm going to do it on my Road Runner too.
At the factory they installed the dash as a complete unit , if you watch Gravyard Carz they do it the same way.
Last time I installed all my wiring in the car then plugged everything in as I installed the dash, it wasn't much fun. this time I'm doing it right and the wires will all be hooked up and in place , except for the few that must be plugged in after installation.
Big Mo
Pa. USA
The windshield is out. I seen the screws that are under the windshield. Looks pretty simple to remove. Thanks Gig John
Big Mo
Pa. USA
I really do not know what I will find back of the dash but I know what has usually happened with this car in the past. Thanks'
perfect time to check out your wires, replace the wiper pivot seals,master cylinder.
tallhair
Moderator
Mascoutah, IL
Thank for the tip Big John! That 53 Windsor Dash on the the stand is like a work of art too
Do you have any pics of the 300 dash from the front when it was on the stand?
And just for laughs, the back of the Windsor dash. I painted that white so you can see it better from underneath.
