Ranger
I recently replaced the wiring harness on my ECU because the PO had it jury rigged with aluminum crimp pin connectors.
In doing so I noticed that it was not wired according to the diagram.
The light blue with yellow tracer wire goes directly to the + side of the coil, bypassing the ballast resistor.
The car seems to run just fine, although it is hard starting, but I think that may be choke adjustment or starting procedure (still experimenting to figure it out).
Is there a reason for it being wired this way?
Is it doing any harm?
Should I leave it or change it and why?
