meepbeep69
Well the car is on the road and the alignment nice.
Along the ride home I got a bunch of thumbs up and a few, "hey your left brake light is out"
I got it home. Checked the light and it was not working. All the outer lights were working before I left the shop.
I played with the left side light ground and the light would come on then go off.
My step son gets in the car and started to wiggle the turn signal and I got the left side brake light and turn signal. The urge to drive was too strong so I decided to be Goober from Mayberry and off we went. If I push forward on the turn signal my brake lights and rear turn signal work fine. So amongst thinking about braking ahead for the drum brakes I have to think push turn signal forward, brake, clutch. (The ground wire from the steering column to the dash was scratched of paint and is clean. I will check it again)
The license plate light was off so I grounded it to the ground on the trunk post phillips head screw and it lit up.
The turn signals work outside, the brights work outside but no lights for them on the instrument cluster. The instrument cluster lights themselves work well.
The fuel gauge is not registering and ditto on the coolant gauge. The tach is working but is off a bit and the altmeter is working.
I know I have a host of items but any ideas on what's up and what and where to ground? Step by step I can pick them off.
The grounds I know I have are the front core support times two for the front lights, battery, back of block to firewall, steering to dash and trunk latch post area screw.
Here's another thing. The flashers work when I put the flasher on and turn the turn signal on. I think that might be the brown wire in the back of the switch.
Any suggestions would be appreciated. Any electrical guru's out there?
