Front seal
bstan70rr
I have never ever worked on any part of a transmission. I have not even pulled a pan to replace the filter or change the oil. I leave these messy jobs for the oil change place.
I have a pretty good mess in front of the transmission pf my 67 Dart, so I will be pulling it and replacing the front seal. I cannot imagine there is anything else I should do while I am there, but I want to consult the experts. I also want to get what I need before I start.
It is a 67 Dart convertible, automatic with a 273.
Thanks in advance.
Very easy to change. Just pull the torque converter out and it is right there. Just like any other seal, knock out the old one and install a new one. The hard part is to R and R the tranny.
Jim S.
White Bear Lake, Mn.
I went a little further with my 727. I pulled the transmission oil pump and replaced the o-ring and I also changed the race that the seal sits in. As mentioned, pulling the tranny is the hard part.
edit. I guess the correct term is bushing not race.......
bstan70rr
good stuff. i will have it out, so i might as well do all that i can to prevent a need to pull it out again.
Do the selector shaft seal while it's out... better yet, make sure it's not leaking now and making you think the front seal is leaking!
X2 usually the front is leaking because the bushing is worn out. Also 904s are notorious for cracked or broken converter snouts. A visual inspection is all it needs
bstan70rr
Well, couldn't that just be good news. But wouldn't yall replace the seal anyway. I have had the car five years, and there is no telling how long since the front seal was replaced. It is not something you can really leave to inspection.
