Head liner going in.
If I am not wrong the first thing is to install the head liner before putting any thing else on the car. That is like window trim and the windshield's. Mine was even raped under the trim for the pop out window in the back and found it under the eve trim over the door's. I am going to tape the front roof and mark where the inside trim bracket's go. Any other suggestion's would be grate. Russ.
Mark it all the brackets and supports. I haven’t installed one myself, but those I’ve seen done, most start in the center and work towards the front and back.
Oh yeah I had a good time installing mine with the windshield and rear window in, wasn’t to bad you gonna put the insulation and boom mat up there, do you have a heat gun it helps
Yes have a heat gun D. 69hemibeep got a band new dome light yes won't for get that part for sure thanks for the head's up buddy's. :thumbsup2:
