Hoosier Bird
Ok, I bought a new dipstick. Here is a pic of the old and new. What you can't see is that on the new one where it says full when lined up with the old one, it says add on the old one. Any comments? :brickwall:
looks different...put it in ...change the oil and filter.. start...wait a couple of minutes...then check it and mark where the oil is on the stickHoosier Bird said:Ok, I bought a new dipstick. Here is a pic of the old and new. What you can't see is that on the new one where it says full when lined up with the old one, it says add on the old one. Any comments? :brickwall:
Hoosier Bird said:Only problem is, I'm not sure what pan I have and I'm not sure if the old dipstick is correct. If anyone has one out of the car and could measure from the swell that stops when it hits the block to the full mark, then I would be set.....
:lmao: :lmao: :lmao: :lmao: :lmao: :lmao: :lmao:george68hemirr said:Hoosier Bird said:Only problem is, I'm not sure what pan I have and I'm not sure if the old dipstick is correct. If anyone has one out of the car and could measure from the swell that stops when it hits the block to the full mark, then I would be set.....
it doesnt matter what pan or dip stick you have ....just fill her with oil and oil filter....5 qts....then read the stick and mark it where the oil line is for full after you started it and then let it drain down for 5 minutes.....done deal
So, what if it's a 7 quart oil pan? Think with your dipstick Jimmy...........george68hemirr said:Hoosier Bird said:Only problem is, I'm not sure what pan I have and I'm not sure if the old dipstick is correct. If anyone has one out of the car and could measure from the swell that stops when it hits the block to the full mark, then I would be set.....
So, what if it's a 7 quart oil pan? Think with your dipstick Jimmy........... [/quote:s2xw0pdl]Hoosier Bird said:george68hemirr said:[quote="Hoosier Bird":s2xw0pdl]Only problem is, I'm not sure what pan I have and I'm not sure if the old dipstick is correct. If anyone has one out of the car and could measure from the swell that stops when it hits the block to the full mark, then I would be set.....
Hoosier Bird said:What a PAIN IN THE ARSE getting this new dipstick tube in............. :brickwall:
Still a stock 383 auto. I took a piece of coat hanger so I could bend it and follow the shape of the tube. Rolled that on a tape measure, came out 16 1/2 inches. Dipstick measured straight from the bottom of the swell that stops it from going any farther into the tube, to the full mark is 20 3/8 inches. Now if a couple more guys do that, and it comes out the same, you can be pretty sure. I just changed a 4 qt. pan to a 5 qt. one and the dipstick is not lying to me, it takes more oil now......JimHoosier Bird said:If someone would measure the length of their tube to the block and then measure your dipstick from where it sits on the tube to the full mark, that would tell us how far the full mark is below where it goes in the block. Then that would be where we could mark it because from the block to the top of the oil in the pan should not change regardless of what pan we have.........I guess everyone is just too busy to help us out......... Good thing I'm the nice guy here........ :devil:
If you get a chance you may. With what we have now, the first is 3 7/8 in the block and the other is 4 3/16. Average so far would be 4 1/32. Now I need to check my old one and new one and see which one is about 4" below the swell to the full...........Now we are getting somewhere.......ACME A12 said:Gary, I was busy working in the yard and then later getting my opening weekend College Football fix and didn't once fire up the computer after yesterday morning. I therefore missed most of this. Would you like for me to follow Jim's lead and take some measurements just for comparison's sake or are you good to go now?
Ray
