Holley Sniper
gnat44
Yes I am using Holley Sniper EFI. Love it just a few bugs in starting. I think it is a fuel problem. I have my return connected a vent line. I ordered a sending unit with a return line so I will see if this is causing my problem.
Skingjack
YEG
Gnat, Any updates on how the Sniper EFI system is worked Gn for you? Considering adding a system to my RR.
gnat44
I am so pleased with the the Holley Sniper Master Kit. No more pumping gas pedal to start engine. I love it.
Couple of questions. Where does the pump go and as far as soft fuel lines do you just change to injection grade soft or does it have to be steel
gnat44
I used hard lines oem and the EFI line included with master kit. If you need more lines you must use EFI grade line. Regular fuel rubber lines can not withstand the pressure from EFI pump.
