Ignition Switch Light - 69Runner
Fred69Runner
Hi All, New to this group, just got a 69 and in the process of getting all the interior lights working. I have the light package option and have the radio, ash tray and glove box removed and needing to know best way to get to the ignition switch light. Is it best to remove the switch or get to it over the top and back of switch. Any suggestions appreciated. Thanks
Welcome from Fla. Sorry no help here. Trying to get one put back together. Hope someone will have an answer for you. :thumbsup2:
Plybeep68
Acceleratii Incredibus
Welcome Fred, if I remember correctly there not too difficult to remove from above the switch, had mine in and out several times
Troadrunner restoration 224.jpg Take the switch out the light is clamped to it. It can be done sitting in the car by taking the front nut off.
Fred69Runner
Thank you for the link to the service manuals. That makes things a lot easier!!!
Fred69Runner
TView attachment 31181 Take the switch out the light is clamped to it. It can be done sitting in the car by taking the front nut off.
I thought that might be the case and will go that route. Thanks so much for adding the pic!! That helps.. I'm always concerned about moving 50 year off wire bundles around, the covering gets brittle, breaks off and then you've got a real mess.. Thanks again for the reply..
