- Joined
- Sep 10, 2008
- Messages
- 14,415
- Reaction score
- 301
l would be flne wlth a prop rod. just take the stock springs off.
If your talking standard springs, your hinges are probably worn and the springs are fine. I just changed mine out and what a difference. I had Restorick redo them.newbaufish said:Has anyone replaced the springs themselves, is that a manageable process without special tools? Mine are quite worn and barely hold the hood open on a windy day.
Basketcase said:would thls lnclude the bolt on ones too Chrls? lf l can get one lt would be bolt on. l would elther go wlth the light sprlngs or just remove my stock sprlngs. but do you see a problem wlth the area the hlnges bolt to? and l would be uslng the factory type hood plns also so the latch wouldn't be a have to.
