I think I'm having the famed rear main seal leak issue that many of you seem to have had. Anyone have a good solution? How hard are these to change? Does motor and tranny have to come out?
You wouldn't think I just had this car restored would you? Live and learn.
Seems odd that the valve cover started leaking as well. I think when the mechanic plugged the breather hole with a chrome cap, it may have created enough vacuum inside the engine to blow some gaskets? Valve cover gasket should be easy enough, but not sure on the rear main.
Thanks,
John
Thanks,
John
