RonLiv
- Joined
- Dec 7, 2017
- Messages
- 1,464
- Reaction score
- 1,163
69 Convertible Roadrunner. Rolled it down, was fine. Went to roll it back up the handle won't turn.
can't get my rear windows to roll down at all.......
With back seat out and the rear panel off you don't have a big access hole lower. Thought their should be. Don't think the car I have even two post would be different. But cant say with a convertible top. Still believe their should be access you can get you arm in. Pretty big opening lower towards the floor on mine where I could vacuum out towards the rocker. But maybe it is more solid due to the convertible top to give it more strength. Hope you get the problem Ironed out it is really a good looking car.
Sounds easy enough. It's going to have to wait a bit though as first I'm 6'6", mostly legs, and I just had hip surgery a couple weeks ago so putting myself in certain positions such as anything to do with the back seat isn't going to be possible. Really not a problem though I'm losing any sleep over, just annoying.not that big of a project. pull the armrest, then you can pull the seat out. then the rear door panel. have a putty knife to work under the door panel to pop the retaining clips out. take a look at the window regulater to see if there is any obvious problem. the glass is held onto the regulater with two bolts. you have to raise/lower the window to get a socket on them.
For $1500 I'll take it off your hands, it's just going to frustrate the heck out of you![]()
Thanks Man.Bet if we get a 18 year old blond that is stacked to the hilt in the back seat you wont have any problem getting back their. You will forget all about that hip problem.Watch out the shark's are swimming it sound's like after the car. It is probably something simple. Miss aligned glass or just need's some silicone on the window channel's. Well it is not that bad of a prob. You will get it my friend. Take care of the hip and let it heel. Russ.
I might be talked into 1600.![]()
