I have fixed lots of parts of an engine, but nothing major. And I have never even thought of building one. I like good ol' stock engines. Anyway, I was just passing some time on ebay and noticed this crate engine. Don't spend too much time on this guys, but what do you think he has into this motor? I am wondering how much it probably cost and how much he stands to make. I AM NOT INT THE MARKET FOR A MOTOR. I am just curious......about the engine....nothing gay. LOL !!!
I took out a lot of salesman type literature and left the specs.
MARK'S PERFORMANCE ENGINES
THE ONLY REASONABLY PRICED, BALANCED & BLUEPRINTED, HIGH HORSEPOWER BIG BLOCK 440 MOPAR!
MOPAR 440 CID / 490 HORSEPOWER COMPLETE STREET / STRIP CRATE MOTOR!!
*** 2 YEAR / UNLIMITED MILE WRITTEN WARRANTY ***
POWER & SOUND OF A BIG BLOCK FOR A SMALL BLOCK PRICE!
MOPAR HP CYLINDER HEADS
FORGED STEEL CRANK
FORGED STEEL RODS
COMP CAMS "PURPLE PLUS" HYDRAULIC HP CAM (#21-671-4, ENGINEERED FOR THE BIG BLOCK MOPAR & BETTER VERSION OF MOPAR PERFORMANCE "484" CAM)....AWESOME SOUNDING IDLE & POWER YET STREETABLE!!!
THERE'S NO REPLACEMENT FOR CUBIC INCH DISPLACEMENT!!
BALANCED & BLUEPRINTED (NO PRODUCTION LINE)
If want to upgrade that old, tired DODGE / PLYMOUTH / CHRYSLER 383, 400, 413, 426 WEDGE or 440, and bolt in extra horsepower & torque then this MOPAR 440 Crate Motor by MARK'S PERFORMANCE ENGINES would be an EXCELLENT choice with 490 Horsepower @ 6100 rpm and 505 FT/LBS of torque @ 4300 rpm. This engine has an AWESOME musclecar idle & lope with enough camshaft to give it ALOT of extra streetable power! If being used with an automatic transmission then a 3000 rpm stall speed torque converter (STILL VERY STREETABLE) should be used. A 750 or 850 cfm carburetor is recommended (Optional: See Below, Add $330 for an EDELBROCK 750 cfm \ $500 for a PROCOMP 850 cfm). This engine runs on leaded or unleaded premium pump fuel. THERE'S NO REPLACEMENT FOR CUBIC INCH DISPLACEMENT!!
The BALANCED rotating assembly (typically includes: Crankshaft, Pistons, Rings, Connecting Rods, Rod Bearings, and Harmonic Balancer) featured in this engine:
DODGE 440 FORGED Steel Crankshaft
DODGE FORGED Rods With ARP Rod Bolts
SPEED PRO/SEALED POWER HP Pistons (9.0:1 Compression / PUMP GAS OK!)
HASTINGS HP Rings
HIGH PERFORMANCE MOPAR / DODGE / PLYMOUTH / CHRYSLER CRATE MOTOR
REGULAR PRICE: $7,590!!!!!!
ALL NEW / NEVER INSTALLED IN VEHICLE!
HORSEPOWER: 490, TORQUE: 505 FT./LBS. (VERY STREETABLE / PUMP GAS FRIENDLY!)
MOTOR COMES AS SHOWN (MOPAR #902 HP CYLINDER HEADS, MOPAR HP CAST IRON DUAL-PLANE HP INTAKE MANIFOLD, HP DISTRIBUTOR, OIL PAN, H. BAL., TIMING COVER, WATER PUMP ETC. AS PICTURED)!!!!
BLOCK: MOPAR / DODGE / PLYMOUTH / CHRYSLER 440
HEADS: MOPAR #902 HP CYLINDER HEADS (WITH HARDENED EXHAUST SEATS FOR PUMP GAS COMPATIBILTY)
CRANKSHAFT: DODGE 440 FORGED Crankshaft
PISTONS: SPEED PRO/SEALED POWER HP Pistons (9.0:1 Compression)
CONNECTING RODS: DODGE FORGED Rods
MACHINE WORK:
Oven Baked / Shottabrated / Jet Washed & Magnifluxed (Completely Cleaned & Checked For Cracks)
Cylinders Bored (WITH TORQUE PLATE) & Finished Computer Honed To Within .0001'' Straightness & Roundness
Align Hone Main Bearing Bores/Saddles
Square Decked Parallel To Crankshaft
Balanced & Blueprinted
PROFESSIONALLY Assembled
ALL NEW PARTS:
MOPAR #902 HP CYLINDER HEADS (WITH HARDENED EXHAUST SEATS FOR PUMP GAS COMPATIBLITY)!
SPEED PRO / SEALED POWER HP Pistons (9.0:1 Compression)
Hastings HP Rings
COMP CAMS "PURPLE PLUS" HYDRAULIC HP CAMSHAFT (#21-671-4, DURATION @ .050": 239I/246E, LIFT: .484"I/.484"E, LOBE SEPERATION: 108) (ENGINEERED FOR THE BIG BLOCK MOPAR & BETTER VERSION OF MOPAR PERFORMANCE "484" CAM) (NASTY MUSCLECAR LOPE / IDLE YET VERY STREETABLE)!
Speed-Pro HP Lifters
Clevite CL-77 Rod/Main/Cam Bearings
CLOYES/SA GEAR True Roller HP Timing Set
ARP Connecting Rod Bolts (180,000 p.s.i)
MOPAR DUAL-PLANE CAST IRON INTAKE MANIFOLD (AWESOME Low-RPM Torque & High-RPM Horsepower)!
MOPAR Steel Shaft-Style Rocker Arm Set
FEL-PRO Gasket Set
NAPA HP Electronic Distributor
Melling Oil Pump
Melling Oil Pump Pickup Screen
Melling Oil Pump Driveshaft
Specialty Products Oil Pan
MOPAR Harmonic Balancer
MOPAR Cylinder Head Bolts
Elgin HP Pushrods
Pioneer Brass Freeze Plugs
Mechanical Water Pump
Mechanical Fuel Pump
Specialty Products Polished CHROME Valve Covers
Copper State Fasteners (Intake Manifold, Valve Covers, Oil Pan, Waterpump Bolts)
EDELBROCK 750 CFM REMAN. CARBUERTOR (OPTIONAL: ADD $330)
PROCOMP/PROFORM "HP/RACE SERIES" DOUBLE PUMPER 850 CFM NEW CARBURETOR, Procomp's new Race Series mechanical secondary carburetors are HAND ASSEMBLED IN THE USA, utilizing a Procomp high-flow carburetor main body. Features include adjustable screw-in air bleeds, high performance down-leg boosters, a high rate airflow section design, a solid billet throttle baseplate, and an adjustable secondary airflow cam bracket. They also have timed and full vacuum tubes for accessories and ease of tuning, a welded throttle shaft, button Torx head throttle plate screws, power valve blowout protection, slip link mechanical linkage, and more. What does all this add up too? Easy--dyno proven horsepower and torque gains without breaking the bank! (OPTIONAL: ADD $500 & INCLUDES 1" SPACER)
Install This AWESOME Crate Motor In Your MOPAR DODGE PLYMOUTH CHRYSLER CUDA CHALLENGER ROAD RUNNER DART VALIANT SWINGER SATELLITE BELVEDERE FURY SPORT FURY BARRACUDA GTX CORONET SCAMP SAVOY STATION WAGON PICKUP TRUCK D100 D200 STREET ROD 1/2 TON 3/4 TON 1 TON DRAG CAR DRAG PROJECT SPEED BOAT JET BOAT V-DRIVE MARINE Application Or Any Street-Strip Rod/Machine, And Make A Statement When You Open The Hood, And (Or) Nail The Throttle! You Will Surely Enjoy For Years The Performance, Reliability & Awesome Sound This Crate Motor Will Make In Your Street/Strip Machine! This can also be used in place of 6 CYLINDER SLANT 6 273 318 340 383 400 413 426
MARK'S PERFORMANCE ENGINES: (623)388-2834
OPEN 8AM-6PM MST M-F , 8AM-4PM MST SAT
FORGED STEEL CRANK
FORGED STEEL RODS
HASTINGS HP Rings
MACHINE WORK:
ALL NEW PARTS:
Hastings HP Rings
FEL-PRO Gasket Set
Melling Oil Pump
Elgin HP Pushrods
