Odd dual stripe on 69 Road Runners
69Hurstsc
I remember seeing this odd stripe in a book years ago on a red Road Runner. Now here's the same stripe on a White one. I know the factory only offered V6_ and V7_ painted and reflective striping, but has anyone else ever seen this striping on another 69?
69Hurstsc
It's a dual stripe with the bottom being thicker. I haven't seen it in person so I'm not sure if it's painted or reflective tape.
First time I've even seen a two tone.
No clue whatsoever on the stripe...but it looks like a very beautiful bird...
I don't recall seeing that stripe around here but it is subtle. What I'm wondering, isn't that body crease a little overdone. The one on my car isn't that noticeable.
69Hurstsc
I found the book that I had seen it in before. It's "Sizzling Cars of the 60's". I know I've seen it on other Road Runners as well.
From our reference section.
A12
:confused:This stripe is on my original Y4 Spanish Gold paint A12 Road Runner and there are photos of it with the stripe going back to 1971????? :confused:
:confused:
Ranger
Woodstock ll
OK, we've established the the stripes were an available option, but what about the two tone paint job?
Have we?
Per the data book, the "Accent" stripe is a single stripe. The "Sport Stripe" is a dual stripe, but it looks nothing like the pic in the OP.
Sport Stripe:
Pretty easy and quite common to add that double pin stripe. Lot's of used car dealers did it too.
If that stripe was OE, it would be paint and wouldn't end with a sharp cut like that one does. It also wouldn't go over that quarter extension seam.
What am I missing on the "two tone paint" part of this discussion? :huh:
Are you saying the Quarter Panel is darker below the stripe? And if so, isn't that just the lighting hitting the QP differently?
Ranger
Woodstock ll
Well, what I meant was that we have established that accent stripes where an option, but not necessarily that the one pictured in post #1 was OEM.
I can't tell if it is or isn't.
Not knowledgeable enough to argue that point, but it sure sounds logical from others I've seen.
Another good point that sounds very logical. All that plus the two tone paint leads me to believe that the one pictured in post #1 is not OEM.
69Hurstsc
I think calling it two tone is a bit misleading. The accent stripe, as we know, was painted on at the factory. Could this simply be a case of an individual applying another pinstripe above the factory accent stripe? Possibly. Below is an unrestored, original Bahama Yellow wearing original paint and original striping. As you can see the stripe stops before the taillight housing.
I'm trying to determine if the dual striping in on the White and Red cars was something applied by the owners or if there was a dealer out there adding them.
Every car dealer in the world has added tape stripes. New and used.
I remember looking at new cars in 1968 and the dealer had sprayed this texture coat on the roof of a brand new, station wagon green, Sport Satellite to make it look like a factory vinyl top... basically adding a little something to make a car easier to sell.
In the seventies, every auto shop and K-mart had a big display of different rolls of tape stripes, so anyone could buy and apply the stripes.
In short... Who knows? It could have been either.
Nobody, and I mean nobody, kept these cars stock in appearance or performance. The number of them come up these days as "original" baffles me at times.
I misunderstood your post. I thought you were saying the double stripe was OEM.
Sorry.
A12
I have never see a thin double on an original '69 Road Runner, GTX from the factory, if the dealer didn't install it then the owner did IMO.
My '68 Road Runner had a white thin painted pinstripe and because it was a St. Louis assembly plant built car with its original fender tag it was on there on the tag under the S with a W at the right end of the second from the bottom line.
MikeR
