Over charging issue.
Introductions
  1. Mike Collins
    Mike Collins New Member
    Jun 27, 2019
    The car is over charging to up to 18-19 volts and is causing ignition problems. I have changed the alternator once and voltage regulator twice and car is acting the same way. I have checked grounds from battery to engine block and block to firewall with a continuity meter and is check good. The voltage regulator doesn’t sit on the fire wall super tight due to the pointed mount bolts. Any thoughts?
  2. 69hemibeep
    21,195
    Regulator grounds through its housing
  3. Russ69Runner
    5,829
    Might could run a braded ground wire to one of the bolts from the engine to the regulator. That may solve the problem. :praying:
  4. ricks_RR
    ricks_RR Well-Known Member
    684
    Jan 22, 2016
    new hampshire
    I had the same problem and what I found was the charging circuit ( wiring ) was oxidized and the voltage regulator was not getting the right reading due to the oxidation .I went to a one wire alternator and my problem went away because a one wire alternator only keeps the battery charged .
    everything works great because I am running on the battery with no strain on the charging circuit or the cars wiring . I put a volt meter in the car and it runs around 13.5 to 14.0 at 55 miles a hour. I did it 4 years ago no problems
    Coyote and Russ69Runner like this.
  5. Big John
    Big John Sit back, relax Don't bitch about the cigar smoke
    5,058
    A couple questions....
    What year car are we dealing with?
    If it's a '69 or older, has it been converted to the dual field/electronic alternator?
    Have you checked the voltage with a different meter? Just tossing that one in, because it does happen.
  6. Russ69Runner
    5,829
    Listen to these guy's we can learn from experience.
    Coyote likes this.
  7. ricks_RR
    684
    Jan 22, 2016
    new hampshire
    with a one wire alternator all you are doing is taking the old charging circuit out but it is still there just tape the two wires that hook up to the alternator .because the wire that go's to the battery from the new alternator and by pass's the old so all you have is a ground from the new alternator and a wire to the battery . the old circuit just stays there so it looks like it is original just tape the two end from the old alternator .
    I used 8 awg wire to go to the battery and to the alternator . so the car is running on the battery and the one wire alternator just feeds the battery when it needs it . what I did was on the back of the gauge in the dash is took the two leads and put it on one stud on the gauge and made a wire to go to a new voltage gauge just so I can watch what the volts are doing .you can buy them at any auto store . this was on a 1969 road runner
  8. Russ69Runner
    5,829
    Be sure to use stranded wire in steed of solid it will carry more current.
    Coyote likes this.
  9. Budnicks
    Budnicks I will apologize to everyone in advance
    542
    Nov 9, 2013
    Sonora Ca.
    welcome from NorCal Sierras
  10. ricks_RR
    684
    Jan 22, 2016
    new hampshire
    yes use stranded wire 8 awg wire this is on 1969 ROAD RUNNER I just put one on 72 road runner and he is very happy his car is running very strong now . if you have the old wiring over the year that wire tarnish's inside the casing and gives fails reading thru out the electrical system in the car .
    if you have the money then buy all new wiring
    Coyote likes this.
  11. Russ69Runner
    5,829
    Oh no don't tell me that. I did not put it in to the budget. Darn It. :(
    Coyote likes this.
  12. oscar holland
    oscar holland Well-Known Member
    158
    Nov 18, 2018
    Forget about budget this kills me every time, but driving a new toyota or lada cost also money and where is the fun in that?
    Coyote likes this.
  13. Rich B
    Rich B Well-Known Member
    192
    Jun 23, 2019
    Minot, ME
    Too also have seen that tarnish/darkening issue on a few of the finer stranded wires over a lifetime. A rule of thumb, if what appears to be a copper wire will not accept flux and soldier- forget it. May get by with crimp connection but brittleness may be a factor there of strands and insulation.
    Only explanation may be an alloy of some sort, substitute and not right portions of copper and additions for the wire. Stranded almost mandatory as mentioned for flexibility and vibration.
    Believe it or not electricity runs on the outer circumference of a cable. Hi voltage substations run busses that look like plumbing pipe; center is hollow; can’t do that with a wire of coarse- go hollow core with insulation and be able to flex, expand and contract. Hollow core also aids with cooling and free air temps also. Already said way too much lol:bs_flag:
  14. Big John
    5,058
    Why are you guys bothering with this thread? The guy has exactly one post (this one), hasn't responded to anything and hasn't been back since the day after he posted this thread. June 28th to be exact.
    Obviously, he's not concerned with anything we have to say or any suggestions we make.
  15. ACME A12
    13,280
    There you go again. Clouding the issue with facts... :rofl:
    Coyote, Basketcase and Rich B like this.
  16. Russ69Runner
    5,829
    Not to respond to the guy that asked the question and don't seem to care. But use welding lead's is one of the best wire's I have found for Dc current. Figured some guy's surfing the site looking for answer's to the same question may get the ideas that we share. Russ.
    Rich B likes this.
  17. Rich B
    192
    Jun 23, 2019
    Minot, ME
    LMAO, I’ve answered on some maybe 10 years old, never noticed the date. Russ, your right about welding cable with the fine strands; those will carry huge amperage.
  18. Russ69Runner
    5,829
    It is like you said the voltage and current flow on the out side of the wire and not through the middle like most people think. I took three year's of electrical theory in an electrical apprentice ship collage. Missed my master's by three point's was a card carrying journey man. I was an electrical foreman for almost 20 year's. I also worked years ago at Tv and radio repair shop. Tedious work searching for the burned out transistor's and resistor's.
    Rich B likes this.
  19. ACME A12
    13,280
    Most of those courses take <1 year. Online courses take ~7 months these days...which I realize was not available back in your Hay Day. What pray tell took 3 years?
  20. Big John
    5,058
    The classes for my Tool & Diemaker apprenticeship did take 4 years. They gave me 2 years credit for my 3 years in a Vo-Tech high school, but it was a 4 year program. Most of the apprentice programs were 4 years in New York State.
    Of course, that isn't a full time deal. That was a couple nights a week after work along with OJT.
Share This Page
