Big John said:Same width for 62-70 (59.2") . A-Body is narrower (55.6"), but you have to deal with the narrower brake drum width. The flange to housing dimension is 1/2" (I think) smaller then the B-body rear.
72duster said:sorry this will be for a b body so 62-70 are the same width?
ACME A12 said:I'll have to defer to Chris or someone with hands on experience on this...I've never had a early B so I have NO practical experience...
moparchris said:Pre 65 8 3/4s use the axle flange nuts and you cant swap in later axles, well I guess you might but you would need to run a spool and green bearings.
ACME A12 said:moparchris said:Pre 65 8 3/4s use the axle flange nuts and you cant swap in later axles, well I guess you might but you would need to run a spool and green bearings.
Chris, I was thinking about this today. Why do you think the conversion to later axles require the use of a spool? I get the dana style bearings to eliminate the end play adjustment (shims in this case based on what I have read previously) but what does this have to do with the carrier? To my point, I run a 741 ('57 to '64 carrier w/ 1-3/8" pinion) SG in my '74 Duster with Yukon axles and green bearings. No spool in there for sure...![]()
