Interesting. I will look at that. Is it tough to pull the cluster?I would leave the seat and pull the glove box and cluster. Lots easier to see things from the top as you hook up the wires.
I can only relate my experience with 69 RR with non ralleye cluster. Yes, a bit of a pain to pull the cluster because you have to pull the switch panel and lower dash pad. Probably helps if you lower the steering column a bit also. I found it easier because I could see everything right side up and could get my hands on the harness to ensure it was routed properly and in the retainers. With a regular cluster you have to be careful with the round 9 pin connector. The new harness will be really tight to put in and it is easy to break the pins off. I had a spare cluster I hooked the 9 pin up to a few times outside the car to spread the connnectors a bit. If you don't have a Tach the only cluster connections are the 9 pin, speedo cable and the Ammeter. While the cluster was out I also ensured my Ammeter connections to the cluster were tight and in good condition. Mine is an AC car so I have a bit less room under the dash also.Interesting. I will look at that. Is it tough to pull the cluster?
Thanks. Mine is non AC and non TachI can only relate my experience with 69 RR with non ralleye cluster. Yes, a bit of a pain to pull the cluster because you have to pull the switch panel and lower dash pad. Probably helps if you lower the steering column a bit also. I found it easier because I could see everything right side up and could get my hands on the harness to ensure it was routed properly and in the retainers. With a regular cluster you have to be careful with the round 9 pin connector. The new harness will be really tight to put in and it is easy to break the pins off. I had a spare cluster I hooked the 9 pin up to a few times outside the car to spread the connnectors a bit. If you don't have a Tach the only cluster connections are the 9 pin, speedo cable and the Ammeter. While the cluster was out I also ensured my Ammeter connections to the cluster were tight and in good condition. Mine is an AC car so I have a bit less room under the dash also.
