Routing pic's of fuel line
If any one has the routing of the fuel line on a 383 post car with out return line. Pic's would be appreciated. Looked into manuals and did not see enough. Wish I had taken more pic's when taking car apart. Have some idea but where all the clips go and through the cross member hole. Any help is appreciated just want to get here done. Russ. :thumbsup2:
dmartin
Russ there should be some 1/4” holes in various places all along the passenger side then a 3/4” hole through the frame rail cause the brake line clips go on the drive side
Thanks Dmartin . Yes I see the holes and knew it went thorough the frame rail. Looks like I have more clips than holes. Just want to get it rite the first time. Russ. Wish I had taken more pic's when taking it apart.
I can show you mine with return line which is the same for a nominal fee lol
Ok I get the joke Bob. Taped out on money my lawyer is getting it all. :lol: so how much is the ransom payment. Yes I could omit the return line. Any help would be appreciated.
Comes out of tank and crosses under the frame rail and then up to front of the car.
Ok quickbird. I bought pre. bent line but the way they stuck it into the box kind of look's funny. Just figured someone might have pic's of the routing. Want to do it once. Seems to be more clips than holes in the inner rocker. Russ.
about 2 feet of rubber gas line to the antifreeze jug zip tied to the rad support......
Did you get what I call nails for under the rocker panel? OK back to front and disregaroadrunner restoration 348.jpg roadrunner restoration 349.jpg roadrunner restoration 350.jpg roadrunner restoration 351.jpg roadrunner restoration 352.jpg rd the hemi return line
I got all the clips from classic and a couple of u straps with screw's. The stainless one has me stumped but think it will fall in place as I go. Thank you for the pic's. I seems all the funky bends go to the gas tank and the front dose not have that many bend's. Well putting it in and checking it out. Mad that they bent it to put it into the box but got it pretty well straighten out. Now I guess you will be on my Christmas list. Bob. :thumbsup2:
Well I got the fuel line in It went pretty smooth. Used all the clips in the bag so must have done ok the only one was the strap with the screw so put it up front. Where the fuel line connects to the fuel pump. That is to the rubber line to the fuel pump. Thanks Russ. :kartman: now time for a beer to celebrate. :drinks:
