BBillyC
With the 4.10 gears and the 29" diameter tires I am going with a 38 tooth speedo pinion. I've never put one in before. Is there anything else I need to replace along with it. thanks B
Roadcuda said:I don't remember if your car is a 4-speed or an auto. But if it is an auto make sure you have a pan under the speedo housing when you pull it out to catch the fluid that will drain out. DAMHIK
