speedo pinion
BBillyC
Winnipeg, Canada
With the 4.10 gears and the 29" diameter tires I am going with a 38 tooth speedo pinion. I've never put one in before. Is there anything else I need to replace along with it. thanks B
dobie
Wooster, Oh
Not that I know of. Some one else can offer more help though im sure. I just picked up a 36 tooth myself for my 3.91's.
A31PKG
Mid-Atlantic
Based on the tooth count, the gear is indexed by rotating the cable mounting flange to the appropriate marked position on the trans tailshaft housing. Consult page 21-5 in the SM for details. No, you shouldn't need anything else.
BBillyC
Winnipeg, Canada
Thanks Guys. Still waiting on the Moser axles and won't cut anything until I have all of the parts.
I don't remember if your car is a 4-speed or an auto. But if it is an auto make sure you have a pan under the speedo housing when you pull it out to catch the fluid that will drain out. DAMHIK :lol:
And jack the back up higher then the front to keep the fluid in the trans.
